Converting notes from previous versions
Command |
Path |
Convert Old Notes to New |
Text |
Databases created in previous versions of the Notes Manager are automatically converted to the current version when they are selected by clicking Choose to select a database.
Databases and notes created in Vectorworks versions prior to version 11 can be converted for use in the current version. Callouts created in those versions are automatically converted to the current format. They can be used as ordinary callouts, keynotes, or database callouts. Other notes objects, such as Text Notes, Keynotes, and General Notes created by previous Notes Manager versions, as well as Vectorworks text objects, must be converted. Vectorworks text objects are converted to general notes.
To convert old objects to the current format:
Select the command. The Convert Old Notes to New dialog box opens. Select the type of old notes to convert.
Parameter |
Description |
All updatable objects |
Converts any note-related items in the drawing |
All selected objects |
Converts any note-related items in the current selection |
Just the following objects |
Select the type of objects to be converted (Text Notes, Keynotes, General Notes from version 8.52 to 10, and text objects) |
Layers/Classes |
Specifies the layers and classes to be searched for objects to convert |
The Conversion Results dialog box displays a summary of the objects converted.
